Hello,
I have an error message on my ST2. I cannot switch between 1-2-3, lights are not working, I have no engine support....
I still have firmware 3.0.4.5
In the info menu:
FW: 3.0.4.5.4768
MCU: ?.?.??
CHR: N/A
M99: N/A
TNT: 2.0
Hello, have a Look to my Note. have had Same Problems.
Change of Systemboard and a Second Unit solved it actually.
Winnitwo: schrieb:Hello, have a Look to my Note. have had Same Problems.
What do you mean with: "Have a look to my note"?
Do you had also Drive Error DX210002?
So, the systemboard is broken? Due to what can this be broken?
Describe pls what you tried to solve this Problem.
Hi,
i have had
drive error 0x210206
drive error 0x210004
drive error 0x230000
BatteryError 0x21000A
last timer
and by the first time also
the Error 0x210002
At the first time the System board was changed
and second time
also a connection board same F.W.
The dealer think it was broken on bumby route
Error 0X210002 is solved.
New controller installed.
