Normale Version: Drive error
Hello:
My apologies for English language, but I hope it is OK. I have ST2, 2017. I believe it is the 6V version. Recently I have started to have the "Drive Error" message. It looks to me the message started after I drove my bicycle under the rain. When a bicycle is connected to a charger, I disconnect a charger and go for a ride the motor is engaged for couple minutes. The drive error message pops out after that. I unlock a battery, disconnect a battery, connect, restart, but the message pops out after that again. Same drill - unplug a batter, reconnect, turn on a bicycle. There is no error message, but a motor is not engaged anymore. I used a compressed air to clean up a connection. It did not fix a problem. Are there any places that should be checked for humidity, water? I wonder if anyone has managed to fix such a problem. Many, many thanks.
Die Controller-Platine im Unterrohr ist bei dem alten ST2 sehr schlecht vor Feuchtigkeit geschützt.
Ich habe nach einem ähnlichen Fehler und dem Einbau einer neuen Controller-Platine (während der Garantie-Zeit) die untere Abdeckung rundum mit einem Gewebeband abgeklebt. Danach gab es keine Fehlermeldungen mehr.
(05.10.2025, 00:40)bronis14 schrieb: [ -> ]Hello:
My apologies for English language, but I hope it is OK. I wonder if anyone has managed to fix such a problem. Many, many thanks.
See some information here:
BTW: There are good tools for translating a language into any other language. My recommendation ist DeepL It can also be used as a browser plugin.
