Normale Version: Recommended torque rear bolts ST1?
Hi,
Excuse me for not writing in German.
I wonder what is the recommended torque in Nm for the bolts of the rear axis of the Stromer ST1?
I recently had to change the inner tire and had to take out the rear wheel. On the bolts of the front wheel, there is an indication of the recommended torque (20 Nm), but I can't find it for the rear wheel bolts.
My bike is a Stromer ST1 Power 48.
Many thanks!
Hi,
don't know about the ST1 but on my ST2 both front and rear axle require the same 20N-m torque
My dealer speaks of 70 Nm for my ST1 25 2015 model. Big bolt ...Needs 140 Nm to loosen back axle bolt.
If you like to compare with ST2
see manual at
https://www.stromerbike.com/en/lu/puncture
