Normale Version: ST2 Replacement brake levers
My brake levers are damaged on my ST2, the shop wanted >250 per brake lever as they needed to replace the whole set of brakes...
The closest part I've found online is here, does anyone know which if any of these is a match / would work? or can they suggest where else to buy a part?
[URL]https://www.hibike.ch/magura-bremsgriff-mt4e-schwarz-4-finger-aluminium-kugelkopf-hebel-schwarz-kabellange-150-mm-ab-mod-2015-pf896e507839d013ffa9fcc3204db9fb5
[/URL]
https://www.hibike.ch/magura-bremshebel-...3b64ef5449
