My phone crashed today (android version 2.3.5) so I did a factory reset and tried to reload the Stromer App from Google play but I get no more results, the Stromer app is gone.
On my wife's phone (android 4.something) it looks as if the app has had an update because the map display is different now, it looks similar to google maps.
The old app worked with android 2.2 and up, maybe the new app requires a higher version ? I can't find it on Stromers website....
Stromer really makes great bikes but it's a pity that ICT and documentation appear to be far below acceptable standards
App-Version: 2.8.4.1
Datum: 14. November 2014
Android-Version: 4.1 oder höher
(gemäss Google Play Store)
I updated the app.
I needed to do a new login but the app said that no bike was attached to the account.
I solved it by asking for a reset of the password (login page of the app) and then it works ok.
Strange.
ere: schrieb:Android-Version: 4.1 oder höher
Dankeschön...
4.1 means that now I have to buy a new phone too to be able to use the app.
When my wife discovered last week the amount I paid for my ST2 she blocked my account...
Joop, I have an app for my iphone. It works well, but is not actual. It starts with only one update per day. The button " reload" does not work and is useless. I have not used my bike for 4 days now (due to Christmass) and all the time there was no update at all. I really doubt wheather Stromer read all the comments at this site. At least they do no react to it.
To get an update on the app the bike needs to be switched on (or at least be in standbymode or on the electronic lock)
Your app communicates over the internet with some Stromerserver and the bike communicates directly with this server over a GPRS (mobile) connection called M2M (Machine to Machine) and this last one appears not to be the most reliable...
I have not yet been able to figure out which telecomprovider is being used in the Netherlands but I suspect that they've chosen the cheapest available....
Like the tubes... Tires on the ST2 are real Schwalbes but they saved some 4 euro's per bike on the tubes.... (Sjing Sjeng Shit)
I have switched on my bike on a daily basis. This is to check wheather the bike can hold his power when it is not in use. From 23-12-14 until now (29-12-14) it has lost 6% already during stand still. So my bike is powered several times per day, but my latest update is from 23-12-14. There is no update during stand still of the bike.
Again....
just swiching the bike on is not enough. The stromer server does not continously monitor your bike, it has to be triggered by the bike itself or by you, when using the app.
Another problem is that connection between the bike and the server indoors is lousy.
so...
place your bike outside in the open, switch it on, wait for a few seconds and then press (while the bike is still switched on !) the renewbutton in the app.
Status-Updates werden von meinem ST2 gesendet, wenn ...
(Google: "Status updates are sent from my ST2, if ...")
[Bild: 20568608kl.jpg]
